CooksDesign Posted April 27, 2025 Share Posted April 27, 2025 Hi everyone, I'm working in Chief Architect X16 Premier and I'm looking for a cabinet door symbol that has two panels, where I can adjust the height of the upper and lower panels independently (not a fixed 50/50 split). Ideally, I'd like to be able to control the proportion between the two panels without having to create a custom door from scratch every time. I need to apply a Wood-Mode door style, so it’s not just a simple shaker or basic door. I thought I remembered seeing something from Renerabbitt or others that might fit this, but I haven't been able to find it yet. If anyone has a symbol like this or suggestions, I'd really appreciate it. I'm still getting the hang of posting questions here, so if I've posted in the wrong section, please be gentle — and feel free to give me a nudge in the right direction if needed. Also, I'm not super savvy with creating doors using polylines and moldings, but I’ll definitely give that a shot once I figure out how to launch the space shuttle. Thanks in advance! Link to comment Share on other sites More sharing options...
DBCooper Posted April 27, 2025 Share Posted April 27, 2025 Quote ...where I can adjust the height of the upper and lower panels independently (not a fixed 50/50 split).. I don't know of a way to do this. It's pretty easy to take a 2 panel door and setup a stretch plane so that one panel is a fixed size and the other panel will vary depending on the height of the door. I can't think of a way to design one so that you can adjust the size of upper and lower panels independently though. Maybe @Renerabbittor @MarkMcmight have a trick (both of them are very clever at figuring out these kinds of things). It really wouldn't be that hard to create a new door symbol every time you need a new one though. You can create a door symbol plan that uses cabinets to build the door model and then it would be very quick to adjust it and generate a new door panel symbol. This thread here has more info about how to do that: 1 Link to comment Share on other sites More sharing options...
Renerabbitt Posted April 27, 2025 Share Posted April 27, 2025 5 hours ago, CooksDesign said: Renerabbitt I could think of a way to do this where it would look correct in 3d but you would see lines around all 4 sides of your adjustable panel rail in any vector view...would that work? 1 Link to comment Share on other sites More sharing options...
CooksDesign Posted April 28, 2025 Author Share Posted April 28, 2025 Renerabbit...I don't use Vector view so it might work Link to comment Share on other sites More sharing options...
Renerabbitt Posted April 28, 2025 Share Posted April 28, 2025 16 hours ago, CooksDesign said: Renerabbit...I don't use Vector view so it might work You don't provide elevations in vector view? Link to comment Share on other sites More sharing options...
CooksDesign Posted May 6, 2025 Author Share Posted May 6, 2025 Sorry for the delayed response. I usually do hand drawn lines but not against vector view. Link to comment Share on other sites More sharing options...
