ChiefUserNurin Posted April 10 Share Posted April 10 Hi guys! I'm a newbie here. Can anyone explain why the template layout came out like this? Anyone can assist me on this problem? All of my plans cannot be export to pdf. It will come out like this print screen. Thanks. Link to comment Share on other sites More sharing options...
joey_martin Posted April 10 Share Posted April 10 Nothing gets exported to PDF, you need to PRINT to PDF. It looks like your line weights are all messed up or the scale you are sending, or.... We need the files to figure this out.. 1 Link to comment Share on other sites More sharing options...
Chrisb222 Posted April 10 Share Posted April 10 6 hours ago, ChiefUserNurin said: Hi guys! I'm a newbie here. Can anyone explain why the template layout came out like this? I'm confused. You're asking about a template layout, but show a SS of exporting a PDF. Export of PDF is only available in a .plan file, not a .layout. Typically we "print" a PDF from a layout using the Print command. You'll get help with a better explanation of your problem, and/or posting the problem file. Link to comment Share on other sites More sharing options...
Solution Opondo Posted April 10 Solution Share Posted April 10 this might be line weight Link to comment Share on other sites More sharing options...
ChiefUserNurin Posted May 13 Author Share Posted May 13 Hi, sorry for the late respond. The problem already solved. Thanks all. Link to comment Share on other sites More sharing options...
