Exact stud placement in exterior walls
ChiefTesoroTX
Go to solution Solved by glennw,
(first question here ever, I've spent hours searching for an answer)
I want to align studs on an exterior wall so that the first stud out from a corner is cemtered a specific distance from the corner (e.g. 18¼" out), with the rest of the studs 24" O. C. from the first.  This is so that the exterior sheathing (a custom 4 × 4 Hardie + EZTrim design) has perfectly spaced studs for nails to hit.
I'd rather not have to manually move every one of them.  Is there a way to set this up and let the auto-framing take over?  Basically something that would emulate "start auto-framing this wall here with this first stud exactly in this spot then do your automated thing 24" for the rest."
One of the best things you could do is to always position your project so a major building corner is at 0,0 on the x /y coordinates. This helps in many walls and for many projects means you woudln't need to add a framing reference.
Even better is to already have the framing reference marker positioned at 0,0 in your template plan and use it as a guide to start drawing walls. Then, if some condition requires the framing to be adjusted, the framing marker can be moved.
