binkpear Posted March 15 Share Posted March 15 I need to create a monolithic slab with a deepened perimeter with NO stem wall. I can not seem to get rid of the stem wall...am I missing something obvious? Link to comment Share on other sites More sharing options...
DBCooper Posted March 16 Share Posted March 16 When you built the foundation, did you chooser "mono slab" in the "build foundation" dialog? If this is what you did, and you are still getting stem walls, then you might want to post the plan because I can't think of a good reason why that would happen. 1 Link to comment Share on other sites More sharing options...
QuickDraw59 Posted June 3 Share Posted June 3 Any resolution to this question? Have same issue. Here in So Cal, 98% of residential is monolithic slab with sill plates directly on top. Maybe a 3"-6" tall stem wall on garage slab only. How do I set my defaults to achieve this? Thanks (new user 3 months X16; 20 years 2020Design) Link to comment Share on other sites More sharing options...
rlackore Posted June 5 Share Posted June 5 Link to comment Share on other sites More sharing options...
