Designing an unvented attic assembly with Metal covering in WUI
flightcrazed
Hi all, working on a project that was originally designed to be an unvented attic with asphalt shingles.  Plan is to change to metal, however the underlayment (Titanium UDL50) has already been laid and is only Class A under asphalt.  I've found that Versashield can bring metal to Class A but not intended for unvented assembly.
Anyone know of another product that could be laid on top of UDL50 to reach Class A for metal?  I've found Atlas FR10 but all the documentation seem to support a commercial roofing system.
Much appreciated!
I am going to look into this as I have a similar situation. I am doing a double roof system on my current project. The first sheathing layer is Zip and then 2x4's on edge to get my overhang and fill that cavity with closed cell spray foam. Metal standing seam over the top of the next sheathing layer.
Much appreciated!
Because of its low perm rating, I don't believe Titanium UDL50 is designed for use over an unvented attic either.  If the builder was okay with that, then I would think Versashield would be just fine as well--if not better.  I think the real problem is the perm rating of any product going over an unvented assembly and the manufacturers resistance to taking on any liability whether actual or perceived.  I believe UDL50 has a perm rating of around 0.05 whereas Versashield has a perm rating of 3 at a minimum.  Major difference and a major improvement in breathabiliy over the UDL50.
Either way, if you really want to do it by the book and decide to go with DensDeck or some other similar fire resistant paneling/sheathing, make sure not to defeat the whole purpose by putting another non breathable roofing layer over the top of it.
