PitMan71 Posted February 25, 2025 Share Posted February 25, 2025 On the attached drawing. At where the front porch and the one-story section intersects the two story siding wall there is a bit of siding missing at the lower edge of the roof. How do I fix this? Thanks Shane ChaneyTwo.plan.zip Link to comment Share on other sites More sharing options...
robdyck Posted February 25, 2025 Share Posted February 25, 2025 Hi Shane, 2 suggestions for you: Delete the ceiling structure for the porch, or reduce the structure depth to 3.5" For the side wall of the Porch, create a wall type that is a single layer and specify the main layer as an air gap. 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 26, 2025 Share Posted February 26, 2025 3 hours ago, robdyck said: Hi Shane, 2 suggestions for you: Delete the ceiling structure for the porch, or reduce the structure depth to 3.5" For the side wall of the Porch, create a wall type that is a single layer and specify the main layer as an air gap. ^^^^This^^^^, although even 5-1/2" ceiling structure would just about work, and you could also just change your side walls from "Interior-4" to "Frame-3 1/2" or some other wall type wih no exterior layers. That gap is just being generated by the exterior finish layer of the wall. Link to comment Share on other sites More sharing options...
