Buster12 Posted February 18, 2025 Share Posted February 18, 2025 I've not been able to find a linear ceiling-surface-mounted light fixture w/ bottom or wrap-around lens in any of the Core, Bonus or Manufacturer's library catalogues. Has anyone found one, or have suggestions on how to create one using one of the standard tubular fixtures in the library w/o a bottom lens? thx Howard Link to comment Share on other sites More sharing options...
Doug_N Posted February 18, 2025 Share Posted February 18, 2025 Are you referring to a trougher like a utility fluorescent style light? A 2 x 4? Link to comment Share on other sites More sharing options...
Buster12 Posted February 18, 2025 Author Share Posted February 18, 2025 Almost. It needs to have a diffuser lens at least at the underside, like in a commercial or kitchen application, not have exposed light tubes like used in a utility application. All the ones I find in the catalogues have exposed tubes and no diffuser lens below them. Link to comment Share on other sites More sharing options...
MPDesign Posted February 19, 2025 Share Posted February 19, 2025 Look at the architectural core catalog, Lighting-Tube Lighting-Surface Mounted-Medium & Wide Then change the object material in the Covering category - from standard glass to Milk-White glass. If you need a frame around it make with a polyline molding tool, and group them together to make a block to copy as needed. 2 Link to comment Share on other sites More sharing options...
