CutAbove Posted February 12, 2025 Share Posted February 12, 2025 I am creating an office with corner barn doors, I am trying to delete the small piece of wall on the edge, so it will show properly in the 3D view, I have adjusted my settings but still have a small section left. I will create the corner of the wall with the doors. Using X16 1 Link to comment Share on other sites More sharing options...
JKEdmo Posted February 12, 2025 Share Posted February 12, 2025 56 minutes ago, CutAbove said: I am creating an office with corner barn doors, I am trying to delete the small piece of wall on the edge, so it will show properly in the 3D view, I have adjusted my settings but still have a small section left. I will create the corner of the wall with the doors. Using X16 You might check out this recent thread with a similar condition. See if there is useful info there. Jim Link to comment Share on other sites More sharing options...
DBCooper Posted February 13, 2025 Share Posted February 13, 2025 The short answer is you can't easily create a corner joined door. I would probably just use a corner joined pass-thru and then manually place symbols for the door panels along the wall. If you want it to look more real, you would also need to place a track symbol manually as well. Link to comment Share on other sites More sharing options...
