HaneyDrafting Posted February 11, 2025 Share Posted February 11, 2025 I discovered this issue this morning. According to tech support the program is behaving as it was intended. I don't remember ever having this issue in previous versions and I have been a user since version 10, yes that was before x. Issue is that the railing beam is being pushed down to the bottom of the eave. This would not be the case when this building is built. 20250211_093522.mp4 Link to comment Share on other sites More sharing options...
CharlesVolz Posted February 11, 2025 Share Posted February 11, 2025 Howdy, I suggest you post your plan if you want someone to explain that behavior. Guesses: That is a post to beam railing wall. Walls moved in 3d. Ceiling ht changed. Remember that roof planes are built on top of wall plate/ceiling settings, not a wall that has been altered. And a wall will build to the default plate/ceiling ht unless it encounters an existing roof or ceiling plane. Link to comment Share on other sites More sharing options...
HaneyDrafting Posted February 11, 2025 Author Share Posted February 11, 2025 Yes, the roof planes are built upon the top of plate. When you drag the plane over the railing wall the beam drops to the bottom of the boxed eave. Makes no sense. I am not new to Chief. Been using it since 2003. Link to comment Share on other sites More sharing options...
SNestor Posted February 18, 2025 Share Posted February 18, 2025 Are you sure it’s not your template? Have you attempted to recreate this in one of chiefs templates? Link to comment Share on other sites More sharing options...
