PLANSAHEAD Posted February 3, 2025 Share Posted February 3, 2025 Hi all. Does anyone on here provide MEP design and/or Electrical Layouts for Residential Home Plans? I am bidding on the design of 10-11 Two Family homes for a Contractor that I have done a lot of work for in the past on similar projects, and now the city is looking for such utility MEP plans. In 42 years of home design, I have never been asked to provide such things on Residential Projects , I have seen them mandated on commercial projects. They are simple ‘production oriented’ homes of approximately 2,000 sq ft per unit. I will be doing the actual house plans, looking for someone to do the MEP’s. TIA. Tony, Plans Ahead LLC Branford,Ct plansahead@aol.com Link to comment Share on other sites More sharing options...
Renerabbitt Posted February 3, 2025 Share Posted February 3, 2025 1 hour ago, PLANSAHEAD said: Hi all. Does anyone on here provide MEP design and/or Electrical Layouts for Residential Home Plans? I am bidding on the design of 10-11 Two Family homes for a Contractor that I have done a lot of work for in the past on similar projects, and now the city is looking for such utility MEP plans. In 42 years of home design, I have never been asked to provide such things on Residential Projects , I have seen them mandated on commercial projects. They are simple ‘production oriented’ homes of approximately 2,000 sq ft per unit. I will be doing the actual house plans, looking for someone to do the MEP’s. TIA. Tony, Plans Ahead LLC Branford,Ct plansahead@aol.com could do it but each muni will have a different MEP requirement..for instance, California would be more involved. Do you have an example set or county requirements? Link to comment Share on other sites More sharing options...
PLANSAHEAD Posted February 4, 2025 Author Share Posted February 4, 2025 Thanks for the reply Rene. Below was the section on guidelines for the project. It was the contractor after meeting with the commission on this project that said the MEP etc would be required. Design Guidelines: All properties must be built in accordance with LCI Residential Design Guidelines, DOH Affordable Homeownership Property Standards for Single Family Housing and 2016 Multifamily Design, Construction and Sustainability Standards-CHFA (Section O only) as outlined in Addendum A to the RFP. If a conflict is present, the DOH Affordable Homeownership Property Standards for Single Family Housing shall apply. Link to comment Share on other sites More sharing options...
Geyatautsilvsgi Posted February 6, 2025 Share Posted February 6, 2025 You might want to ask them clarify what depth of detail they are asking for. Sometimes it may be just the basic MEP schematics and a few riser diagrams or sometimes it may be something more substantial that might need a Licensed professional to do. Never hurts to ask. Link to comment Share on other sites More sharing options...
Hammer7 Posted February 6, 2025 Share Posted February 6, 2025 You can also ask to see a recently approved project as a sample for what they are looking for as it is public record. Link to comment Share on other sites More sharing options...
