JFH-DFH Posted January 30, 2025 Share Posted January 30, 2025 Hi I am trying to get the brown roof to fit with in the roof line but it will not drag to the dimensions. Can any one help with this? Thank you Link to comment Share on other sites More sharing options...
rwdozier Posted January 30, 2025 Share Posted January 30, 2025 Try this: In the attic Wall Specification, Structure, Platform Intersections, check the box "Stop at Ceiling Above". Link to comment Share on other sites More sharing options...
TeaTime Posted January 30, 2025 Share Posted January 30, 2025 Also make sure that Default Wall Top is checked. All you should need to do is lengthen the wall to fill that space, don't try to shape it yourself. Link to comment Share on other sites More sharing options...
JFH-DFH Posted January 30, 2025 Author Share Posted January 30, 2025 Didnt work. I tried pulling the wall up from the first floor and that didnt work either Link to comment Share on other sites More sharing options...
TeaTime Posted January 30, 2025 Share Posted January 30, 2025 37 minutes ago, JFH-DFH said: I tried pulling the wall up Don't. That turns off the Structure Panel's Default Wall Top Height setting. Make sure that's checked on all walls. I assume it's creating a gap where you're only getting a half-gable there, that's somewhat common. Just grab the right side of the wall and yank it over. If that's not working for some reason, post the plan file so we can look at it. 1 Link to comment Share on other sites More sharing options...
