Gtomer Posted January 20, 2025 Share Posted January 20, 2025 Hi, Thanks for the help last time I posted. I need the door headers to display as a single solid header, not 2 2x's (Here in Cali I get brownie points for using LVL for headers) Cant seem to figure it out. Also, In an cross section cut view, the terrain doesnt seem to have a cut pattern, which is very useful. Is there a box Im not checking? My online search has left me thinking that I need to draw this CAD style manually?! Thanks Link to comment Share on other sites More sharing options...
SHCanada2 Posted January 21, 2025 Share Posted January 21, 2025 cut pattern? what are you looking for.. a picture might help Link to comment Share on other sites More sharing options...
DBCooper Posted January 21, 2025 Share Posted January 21, 2025 Quote I need the door headers to display as a single solid header, not 2 2x's (Here in Cali I get brownie points for using LVL for headers) Cant seem to figure it out. You can setup your door defaults to use the headers you want. Just set the count to 1 and the type to LVL. Also, you can group select your door defaults if you want to change them all at once to be the same style. Quote Also, In an cross section cut view, the terrain doesnt seem to have a cut pattern, which is very useful. Is there a box Im not checking? My online search has left me thinking that I need to draw this CAD style manually?! I don't think there is anything automatic. We have some things like poche fill and "below grade" display settings in the cross section camera dialog but these won't give you a fill style for the terrain itself. I usually just use add cad manually when I need to. You can sometimes use the view to cad detail to make it easier to get a closed polyline that you can add a fill style to and then copy back into the elevation. Someone else might have some other tricks to make this easier. And, as Jason mentioned, adding pictures for what you want can really help people understand better. Link to comment Share on other sites More sharing options...
SHCanada2 Posted January 21, 2025 Share Posted January 21, 2025 If you want only the terrain below grade to have a pattern, you could do something as shown in this Link to comment Share on other sites More sharing options...
