WhistlerBuilder Posted January 16, 2025 Share Posted January 16, 2025 Hello Chiefers, I am having a weird issue where the size column in the window schedule is rounding up to the whole inch. I need specific measurements to the fractional inch. The RO category can do this, but for some reason the size column reports differently. Is there a way to change this? Also... is there a way to get the window size reported in mm scale in the same schedule as a plan set using imperial? Canada has this weird hybrid system in construction where we use both imperial and metric. It gets confusing and silly sometimes. It gets even worse when you are ordering high performance windows from Europe for your project in North America... Any help here would be appreciated. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 16, 2025 Share Posted January 16, 2025 A few different solutions here. The easiest might be to simply ditch the size column and use the Width and Height columns. This way you can click on the Number Formatting tab and format those dimensions however you want. The other most obvious answer is to use a Custom Object Information Field along with a custom macro. 1 Link to comment Share on other sites More sharing options...
DBCooper Posted January 16, 2025 Share Posted January 16, 2025 Pretty easy to just use the built in width and height columns. You can add a second width and height column and then change the number format to mm rounded to 0 decimal places. 1 Link to comment Share on other sites More sharing options...
