Solution DianeP Posted January 15, 2025 Solution Share Posted January 15, 2025 UPDATE: Defective mouse seems to be the answer. I had another one that I hooked up and it seems to be working properly now. Does anyone have this issue and know what could be causing this? I normally can click on an object and then decide to open the dialog box or do some other function. For instance, change the dimension of it from another object. Any ideas on how to get my mouse back to functioning correctly. I have rebooted my computer. I just went back in to a couple of drawings and it is sort of strange how my mouse is reacting. Sometimes I select a door and it doesn't open the dialog box and sometimes I select a different door and it does open the dba. I kept clicking around to see how it would react. Now everything I select in that drawing, door, cabinet, fixture, etc. will open the dba and I have to hit esc to cancel the dba. It did the same thing in another drawing. Defective mouse? Windows update issue? Or a CA issue? ¯\_(ツ)_/¯ Thanks in advanced, Folks! Link to comment Share on other sites More sharing options...
glennw Posted January 16, 2025 Share Posted January 16, 2025 Just a wild guess, but...If you are still having trouble, have a play with Preferences>Appearance>Contextual Menus> Link to comment Share on other sites More sharing options...
DianeP Posted January 16, 2025 Author Share Posted January 16, 2025 Thanks for assistance. I will look at this to see if it helps when I have more time. Link to comment Share on other sites More sharing options...
