chief license active on another computer?
K-Lynn
Go to solution Solved by DBCooper,
I just updated my Mac laptop to macOS Sequoia 15.2. When I opened chief it said please activate your software. I clicked activate with current key. Then the first image below came up saying chief is currently active on another computer. I went to my digital locker in chief and clicked 'make available'. The second image below popped up saying click ok to make available for use on a different computer. I hit cancel. I have only used my chief key on this one laptop with a monitor. Why is chief saying it is active on another computer and what should I do to continue working without disrupting my current projects?
  • Solution
I think it's a problem with mac sequoia.  I found this tech article when I searched for mac + license so maybe it will help:
https://www.chiefarchitect.com/support/article/KB-03198/troubleshooting-license-authentication-issues-after-updating-to-macos-sequoia-15.html
If you can't fix it, you are probably going to have to call tech support.
  • 3 weeks later...
Hi,
Chief Architect has a program update available to resolve the activation issue introduced in Mac OS Sequoia (Mac OS version 15). This patch applies to Chief Architect X16 and Home Designer 2025 products.
Prior to installing this update, you will first need to deactivate your software. After the patch is installed, the software will activate on your computer and resolve the activation issue caused by changing Wi-Fi networks.
Please note that after the patch is installed, X16 and Home Designer 2025 will be using different identifiers than prior versions so if you switch between this version and an earlier version (like X15 or Home Designer 2024) you will need to deactivate.
Patch Installation Instructions:
If you have any questions about the process please contact our Technical Support team.
Carrie
