LotzCC Posted January 13, 2025 Share Posted January 13, 2025 My deck border is set to 2 planks but is not displaying as set. See attached image and plan file. Because the auto railings do not build as I would like them to, I originally drew the deck without railings, and with the intention of adding them later. The borders did display in my original drawing, but must have changed while I was experimenting with adding and manually adjusting the railing. I also tried deleting the deck and then copying and pasting the deck from my originally plan file. Deck 1.1.2.zip Link to comment Share on other sites More sharing options...
MoeGia Posted January 14, 2025 Share Posted January 14, 2025 I didn't download your plan but be sure the exterior walls of the deck is set to railing. If it's not, Chief will think it's not the edge of the deck but against a building. HTH, Link to comment Share on other sites More sharing options...
MarkMc Posted January 14, 2025 Share Posted January 14, 2025 Not sure what you want for railings but some control can be gained by reversing wall direction after a split. Put a quick sample there. Stair rails sometimes drawing rail that follows stairs in center then moving helps BUT your retaining walls interfere, and they want to snap to the invisible deck walls. Worst case can get one correct size (say by cutting the retaining wall(s) temporarily) and make a symbol-PIA to place the symbol though. Link to comment Share on other sites More sharing options...
