RangerKatana Posted January 8, 2025 Share Posted January 8, 2025 Hello, City wants elevation reference point to be the top of curb 0. There is 20’ between the curb and grade level at the house so using 5% slope the grade at the house + 12” I want the first floor to be 12” above the grade at the house. And I need 18” crawl space. How do I do the setting? Thank you. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted January 9, 2025 Share Posted January 9, 2025 Tips & Techniques is for posting your tips for how to do something. So here's my tips for you Check the Help - it's searchable and quite extensive Once you've exhausted that and haven't found the answer, post your question in the Q&A Forum 2 Link to comment Share on other sites More sharing options...
SHCanada2 Posted January 9, 2025 Share Posted January 9, 2025 I will give some tidbits, keep your top of first floor subfloor at 0, per default. Create your terrain and set at 12" below the first floor. Create a terrain region at the curb with -12. Then create a story pole and use a grade reference(-24") to show the curb at 0 2 Link to comment Share on other sites More sharing options...
