Archije Posted December 28, 2024 Share Posted December 28, 2024 Not sure if this is appropriate question for this forum, this is my first time here. How expensive can it get to fix a floor that has sloped, i.e. seems to be sinking, on a main floor that is above a basement that is only a crawl space? The walls of the main floor are also only about 7ft in height. The home is a 2-storey and seems well-maintained other than these issues. Thanks. 1 Link to comment Share on other sites More sharing options...
SHCanada2 Posted December 29, 2024 Share Posted December 29, 2024 probably a better forum is the off topic. This forum is for the use of the softare. As well you probably need to provide more information, like are there posts underneath a beam, mid span, and is that at the same elevation as the walls Link to comment Share on other sites More sharing options...
GaryOhmer Posted December 31, 2024 Share Posted December 31, 2024 sounds like you have foundation that has settle or framing shrinkage - one of our projects we used pressure treated insead of concrete - shrink a 1/2" Link to comment Share on other sites More sharing options...
