EdwinB Posted November 26, 2024 Share Posted November 26, 2024 How can I align the top brick wall with a CMU lower wall. The lower part is a walkout basement. Chief 16 Thanks Link to comment Share on other sites More sharing options...
DBCooper Posted November 26, 2024 Share Posted November 26, 2024 Take a look at your wall type definition for the brick wall. Look at the wall properties and see what the wall layer is set to for the foundation alignment. Also, check to see if there is an offset set. Should be able to get what you want using these settings. Link to comment Share on other sites More sharing options...
robdyck Posted November 26, 2024 Share Posted November 26, 2024 Link to comment Share on other sites More sharing options...
EdwinB Posted November 26, 2024 Author Share Posted November 26, 2024 Thanks. I'm still off the mark level-0 slab foundation level-1 walkout basement level-2 main floor plan...... Link to comment Share on other sites More sharing options...
DBCooper Posted November 26, 2024 Share Posted November 26, 2024 So when you build level 2, the program should use cmu walls like you have on your first floor. If you set your "wall resize about" to outer surface before you change them all to brick, then they should be aligned the way you want. The other way to do it would be to make everything in the brick wall part of the "main layer". This might have unwanted side effects though for things like dimensions. Other than that, I think you would have to move them manually to align them. Link to comment Share on other sites More sharing options...
EdwinB Posted November 26, 2024 Author Share Posted November 26, 2024 Switching to manual. Thanks. Happy landings Link to comment Share on other sites More sharing options...
