Floor Joist Framing to change Direction, to perpendicular where specify,
buzzsaw204
hi,
Is there a setting to change a joist direction perpendicular, in a specified area??
In a case where a house canteliver, I would like to have my Joists run perpendicular to the main floor area.
When I indicate my direction with the arrows,   it would not allowed to do so.
2 hours ago, DBCooper said:
How would the program ever know where to split the framing if you drew more than one joist direction line in the same platform?
This is what it does when you add some bearing lines/walls to tell it what you want:
AWESOME!! thank you DBC
