PhillipsPlans23 Posted November 24, 2024 Share Posted November 24, 2024 For the life of me I can not figure out why these walls stopped connecting after I made this new template. I am sure its something easy. Any help would be appreciated. Link to comment Share on other sites More sharing options...
Rpadge Posted November 24, 2024 Share Posted November 24, 2024 Probably should post the plan. Link to comment Share on other sites More sharing options...
DBCooper Posted November 25, 2024 Share Posted November 25, 2024 Check the wall types and make sure you didn't accidently mark them as "partition" walls under the wall properties. If not that, then post the plan so someone can poke around in it. Link to comment Share on other sites More sharing options...
PhillipsPlans23 Posted December 1, 2024 Author Share Posted December 1, 2024 I have zipped and attached one of the files I am talking about. Test - PDS - Residential Template.zip Link to comment Share on other sites More sharing options...
DBCooper Posted December 2, 2024 Share Posted December 2, 2024 I did not spend much time looking at your plan but I found a few problems right away. - your exterior walls are marked as attic, no locate, and no room definition. This will lead to all kinds of problems. Did you mark them this way on purpose? My guess is that this is the main reason your walls are not connecting properly. - your plan is also about 6 miles away from the origin at 0,0. I know you can start having all kinds of weird problems when you get very far from the origin but I'm not sure where that starts happening. - your PDS working plan view has your dimension defaults set to use the 1"-30' scale which seems a bit large. 1 Link to comment Share on other sites More sharing options...
PhillipsPlans23 Posted December 2, 2024 Author Share Posted December 2, 2024 16 hours ago, DBCooper said: I did not spend much time looking at your plan but I found a few problems right away. - your exterior walls are marked as attic, no locate, and no room definition. This will lead to all kinds of problems. Did you mark them this way on purpose? My guess is that this is the main reason your walls are not connecting properly. - your plan is also about 6 miles away from the origin at 0,0. I know you can start having all kinds of weird problems when you get very far from the origin but I'm not sure where that starts happening. - your PDS working plan view has your dimension defaults set to use the 1"-30' scale which seems a bit large. I noticed that after putting that up there. I am not sure why it did that. I will put up a better plan today. Link to comment Share on other sites More sharing options...
