KatiePCD Posted 13 hours ago Share Posted 13 hours ago Hello All! Hoping to troubleshoot these areas with you. The gutter highlighted in pink is correct - the gutters highlighted in blue develop all these extra lines when joined with the gable plane to the left of it. They are using the same default gutter just unsure why the extra lines are popping up? When I drag the blue roof plane back from the yellow the extra lines disappear. The yellow highlighted roof planes are see through and I cannot seem to figure out why. Link to comment Share on other sites More sharing options...
Gawdzira Posted 11 hours ago Share Posted 11 hours ago Your attached image failed to load. Link to comment Share on other sites More sharing options...
KatiePCD Posted 10 hours ago Author Share Posted 10 hours ago 22 minutes ago, Gawdzira said: Your attached image failed to load. Thank you for letting me know, can you see it now? Link to comment Share on other sites More sharing options...
Mark3D Posted 7 hours ago Share Posted 7 hours ago Maybe upload your plan and someone should be able to help if plan is to big try compress it Link to comment Share on other sites More sharing options...
Gawdzira Posted 7 hours ago Share Posted 7 hours ago Uploading your plan will probably get you a better answer as this could be a number of things. Likely problem is that one of the roof planes is misaligned and that is why the rake board is not building. Link to comment Share on other sites More sharing options...
