Cadwork22 Posted November 10, 2024 Share Posted November 10, 2024 I apologize in advance for this. See attached, I'm trying to create a hip roof, my default for some reason is a short gable. Just a time saving question, checked YouTube, couldn't find much. Link to comment Share on other sites More sharing options...
basketballman Posted November 10, 2024 Share Posted November 10, 2024 Change end walls to not be gable Pretty easy search 1 Link to comment Share on other sites More sharing options...
Cadwork22 Posted November 10, 2024 Author Share Posted November 10, 2024 This is how far I've got; do you know how to pull the triangles back to make a ridge in between, usually this done automatically, not sure, probably in settings or something. Link to comment Share on other sites More sharing options...
Solution GeneDavis Posted November 10, 2024 Solution Share Posted November 10, 2024 Select the two end walls, at right and left side of building. In ROOF tab of wall dialog, change the pitch to something higher. If it is for example, 3:12, jack it up to 6:12. Autoroof should then generate the roof with a ridge parallel to the front and rear walls. Now play with all these pitches until you get what you want. Link to comment Share on other sites More sharing options...
Cadwork22 Posted November 10, 2024 Author Share Posted November 10, 2024 Thanks, huge time savior! Link to comment Share on other sites More sharing options...
