Cadwork22 Posted October 31, 2024 Share Posted October 31, 2024 If anyone has time, could you help with what I think is simple question and a huge time savior. There is a space between the loft floor and the and the ceiling beneath. I tried the structure options...see attached, thanks in advance. Summit.zip Summit.zip Link to comment Share on other sites More sharing options...
Solution mtldesigns Posted November 1, 2024 Solution Share Posted November 1, 2024 2 hours ago, Cadwork22 said: There is a space between the loft floor and the and the ceiling beneath Did you build your flooring? Link to comment Share on other sites More sharing options...
Cadwork22 Posted November 1, 2024 Author Share Posted November 1, 2024 Appreciate it I hadn’t considered framing thanks! Link to comment Share on other sites More sharing options...
mtldesigns Posted November 1, 2024 Share Posted November 1, 2024 1 hour ago, Cadwork22 said: thanks! YOUR WELCOME! Link to comment Share on other sites More sharing options...
ValleyGuy Posted November 3, 2024 Share Posted November 3, 2024 I ran into this problem before, same result of not filling in between the floor and the ceiling, but because of a different issue. You must use a wall that has layers, it is the wall's layers that becomes the fill-in material. I used a wall divider, that had no material layers, to define the loft with a separate rail (no room, no locate) inboard a little. Link to comment Share on other sites More sharing options...
