ChiefUserKatie Posted October 30, 2024 Share Posted October 30, 2024 Hello, does anyone know of a way to automate the plan display callout label for elevations? Ex; E1, E2, E3, E4, etc. Chief does this, but its rare that I get the order / amount of elevations needed correct on the first try. Some of my files have a lot of elevations; as I am creating a plan set I often have to go back and add an elevation / take one out & it throws off my order. Not a big deal to go back and change them manually, but there's more room for error when that happens. For example, say I have a plan set with E1-E20 elevations and then realize I need to add an elevation that would be E4.. I then have to go back to E4-E20 & manually add 1 to each of those numbers so they are now E5-E21. I like to keep the order neat so the order makes sense as you are looking at the actual elevations. Thank you in advance! Link to comment Share on other sites More sharing options...
Solution robdyck Posted October 30, 2024 Solution Share Posted October 30, 2024 There is no way to auto-rename them. What I prefer to do in the instance you describe is to add the new elevation and name it E4.1...and so on. I simply don't have time to redo everything because of a single change and over the years I have learned to accept the function of the software rather to fight against it. Adaptation is key! 1 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 30, 2024 Share Posted October 30, 2024 Personally, I number each room's elevations beginning with 1,2,3,4 and name them in the Project Browser. 1 Link to comment Share on other sites More sharing options...
robdyck Posted October 31, 2024 Share Posted October 31, 2024 For room / wall elevations, these can be automatically created in a logical order using the 'Create Room Elevation Views' tool. 1 Link to comment Share on other sites More sharing options...
ChiefUserKatie Posted November 1, 2024 Author Share Posted November 1, 2024 Thank you @Joe_Carrick & @robdyck, these are both helpful work arounds! 1 Link to comment Share on other sites More sharing options...
