LotzCC Posted October 14, 2024 Share Posted October 14, 2024 See attached image of Chief door component with the exterior door hardware not sitting on the face of the door, but sitting slightly under the face of the door. I doo not see a door hardware placement option for this one. Please advise. Link to comment Share on other sites More sharing options...
ericepv Posted October 14, 2024 Share Posted October 14, 2024 Please post your plan. Link to comment Share on other sites More sharing options...
LotzCC Posted October 14, 2024 Author Share Posted October 14, 2024 Hi Eric, See attached plan file. My Template 1.0.planFetching info... Link to comment Share on other sites More sharing options...
ericepv Posted October 14, 2024 Share Posted October 14, 2024 Hmmm, I've never run into this before. I thought there might be an adjustment in the edit tab for the handle but no luck. The only solution I can think of is to specify 'none' for the exterior hardware and then place it manually. Have you contacted tech support? Link to comment Share on other sites More sharing options...
ericepv Posted October 14, 2024 Share Posted October 14, 2024 One thing that did work for me was to change the thickness of the door to 1/4". Not ideal but it works. Link to comment Share on other sites More sharing options...
LotzCC Posted October 14, 2024 Author Share Posted October 14, 2024 Thanks for trying. I will send the issue to support if needed. Link to comment Share on other sites More sharing options...
DBCooper Posted October 14, 2024 Share Posted October 14, 2024 Are you still using X14 or did you bring your X14 template forward? The reason this matters is that I think it has something to do with that door symbol and the fact that part of it sticks out. I just opened the door and replaced it with the E21 from the X16 library and then it worked fine. My guess is that they fixed something in the symbol that was causing the problems. In any case, you could probably just use a different door symbol (like maybe E20 instead) and not have that problem. Link to comment Share on other sites More sharing options...
LotzCC Posted October 17, 2024 Author Share Posted October 17, 2024 I'm using x15. I have contacted support and will follow up here with a note about the result. Thanks Link to comment Share on other sites More sharing options...
