Material - Transparent [ Gap Vs Area ]
Joe_Carrick
If I have an object defined as an "Area Material 100% Transparent", it's transparent in all Render Types except "Vector" and it can be selected.  I can put the object on a Layer that can be turned off - but then I have to turn the Layer on in order to select it.
If I have an object defined as an "Gap Material 100% Transparent", it's transparent in all Render Types but it can't be selected even if the Layer is displayed.
Is there any way to resolve this so that the object can be selected and for it to still be transparent in Vector Views?
Have had this issue before. Only way I have been able to click on is in plan view. It seems to behave in a similar fashion as a door opening if the casing is deselected. Have not tried this but maybe setting the transparency to only a few percentage points might do the trick and yet not show in the renders.
Graham
