HumbleChief Posted March 14, 2015 Share Posted March 14, 2015 Simple box house 15 x 30 ft.. Auto build foundation - stem walls. Foundation appears around the perimeter. How do you place more stem walls. In this simple example just one more to divide the 30 ft length will be fine. It's NOT a bearing wall, just a wall that breaks the floor joists over. I want to keep auto build foundation on but manually building any foundation wall will turn auto build off. Can it be done with auto build foundation on? Link to comment Share on other sites More sharing options...
glennw Posted March 14, 2015 Share Posted March 14, 2015 Larry, Select the wall, open it's dbx, Structure Panel, Framing, check Create Wall/Footing Below. Build Foundation. I don't know why it is under Framing, but it is. Link to comment Share on other sites More sharing options...
HumbleChief Posted March 15, 2015 Author Share Posted March 15, 2015 Sorry Glenn, Bad explanation. There's no wall above at all. Just want to create a stem wall below, automatically. Figured it out with your help - Thanks. http://www.screencast.com/t/axbPsCxo4di Link to comment Share on other sites More sharing options...
