DavidInMaine Posted October 6, 2024 Share Posted October 6, 2024 Hi all. Can't figure out what I've done for my roof overhangs to have these unconnected shapes that look like lowered soffits just floating in air. (it is not happening on the right side bump out with separate roof line). Would appreciate any insights. thanks, David Link to comment Share on other sites More sharing options...
DBCooper Posted October 6, 2024 Share Posted October 6, 2024 Maybe your fascia is smaller than your roof structure. Link to comment Share on other sites More sharing options...
DavidInMaine Posted October 6, 2024 Author Share Posted October 6, 2024 Thanks for your reply. Could you advise how I would determine if that was the issue? Link to comment Share on other sites More sharing options...
DBCooper Posted October 6, 2024 Share Posted October 6, 2024 See picture below. All I did was make my gable fascia 4" which is much smaller than my roof thickness causing the gap. 1 Link to comment Share on other sites More sharing options...
DavidInMaine Posted October 6, 2024 Author Share Posted October 6, 2024 Reducing to 4" didn't work for me. I increased from 7 1/4" to 10" and it at least hid the shapes on the left side, but they are still hanging much lower than this on the right side. (Duplicating left roof to replace the right roof still had same issue so it's something in a wall or something and not the roof). Not sure what else to try? Link to comment Share on other sites More sharing options...
CharlesVolz Posted October 6, 2024 Share Posted October 6, 2024 2 hours ago, DBCooper said: See picture below. All I did was make my gable fascia 4" which is much smaller than my roof thickness causing the gap. DB was saying that he reproduced your problem situation by reducing fascia to 4". Make your subfascia deeper or your roof structure (rafters probably) less deep. Best, Charles Link to comment Share on other sites More sharing options...
DavidInMaine Posted October 6, 2024 Author Share Posted October 6, 2024 Monkeying with the subfascia helped mask it. thank you. Link to comment Share on other sites More sharing options...
