Simple time saver
Cadwork22
Go to solution Solved by DBCooper,
  • Solution
I think it is pretty easy to build that roof using the automatic roof tools.
I set the auto roof to build at 5:12 and then set the pitch to 2:12 for the lower wall where the shed is.  Need to set the side walls for the shed to "full gable" and the upper shed wall to "high shed".  I also had to go into several of your rooms and tell them to have a roof over them (not sure why they were turned off).  I then set the overhang on the end wall to a small value (like 1") and reset it to "default wall top".
I also noticed that some of your second floor walls were not aligned with the walls on the first floor.
  • Like 2
