winterdd Posted September 24, 2024 Share Posted September 24, 2024 Is there a way to remove the structure from a balcony like pictured below to expose the floor structure? I know you can do it in the framing plans but the actual hardie board closure material is what needs to be gone. The balcony was built with railing walls. internet mine Link to comment Share on other sites More sharing options...
rlackore Posted September 24, 2024 Share Posted September 24, 2024 You could define the balcony as a Deck, build the framing, then delete the rim board: 1 Link to comment Share on other sites More sharing options...
winterdd Posted September 24, 2024 Author Share Posted September 24, 2024 18 minutes ago, rlackore said: You could define the balcony as a Deck, build the framing, then delete the rim board: That's a good idea, thanks. Link to comment Share on other sites More sharing options...
DBCooper Posted September 24, 2024 Share Posted September 24, 2024 You should even be able to put a custom profile on the end of those joists if you want it look just like the picture. Link to comment Share on other sites More sharing options...
winterdd Posted September 25, 2024 Author Share Posted September 25, 2024 9 hours ago, DBCooper said: You should even be able to put a custom profile on the end of those joists if you want it look just like the picture. Yep. Added a pretty cool rafter tail to em. Link to comment Share on other sites More sharing options...
