Hole In The Wall
Joe_Carrick
Just another mouse trap to offer up here.
I insert a window.
Make the dim's 12 x 12 or whatever size you want your niche.
Make the window type solid.
Strip it down to bare bones- no casing, lintel, or sill
Shrink the sash down to 1/16" all the way around
Then adjust your materials to your preference.
You can save this as a symbol for later use too.
The draw back to this is that you have to fill the window with a poly-solid on the back side if it is exposed and in view.
For the floor plan on the layout I usually just cover the window area with a sold box, the color of the walls I use.
....The draw back to this is that you have to fill the window with a poly-solid on the back side if it is exposed and in view.......
Have you thought of using a door with a different material on each side.  Works very well in render,  in vector you will have a few stray lines.
  • 4 years later...
    30077
    DznrDavid
    DznrDavid
