HumbleChief Posted September 18, 2024 Share Posted September 18, 2024 https://www.youtube.com/watch?v=LOFbYU1yiI8 Link to comment Share on other sites More sharing options...
Solution DBCooper Posted September 18, 2024 Solution Share Posted September 18, 2024 I have seen something like this happen. It probably has nothing to do with the paint and I would bet good money that if you just opened up the stair dialog and clicked OK that it would do the same thing. My guess is that you either drew the walls with a small (<1") gap or overlap with the sides of the stairs. When you do anything to the stair, then Chief tries to align the stairs with one of the walls which ends up moving it slightly. The walls then get cut off by the stairs instead of following along the sides. The solution is to turn off the railing display in plan view for the stairs and landings and make sure everything is positioned and aligned exactly the way you want. These are just guesses and if it's not that then I have no idea. Link to comment Share on other sites More sharing options...
HumbleChief Posted September 18, 2024 Author Share Posted September 18, 2024 I'll be darned if the walls were just out of alignment enough to throw things off. Thought it was kind of entertaining. Annoying but entertaining. THANK YOU Link to comment Share on other sites More sharing options...
