Stairwell thru Retaining Wall
RGerbig
Create an exterior "room" at the lower terrace area.
Example... use invisible walls to create the terrace area.
Make sure that they all connect, and then use the settings for the "room" to show a slab floor with pavers.
No roof and no ceiling.
Set the floor height to whatever it needs to be below the main house height.
Maybe it's a few feet? Not sure. The image doesn't show. Anyway...
Use the "landscape walls" to draw over the invisible walls ----> to create the stone walls as per the image.
Then use the stair tool to launch the stairs going up from the exterior room until it meets up with the grade.
It's sounds complicated, but it's not too bad. You will get.
