jjifmeyer Posted September 12, 2024 Share Posted September 12, 2024 Trying to create a landing for some deck stairs leading down to a concrete slab (patio). I cant figure out how to lower the landing? Thanks in advance! Jimmy Link to comment Share on other sites More sharing options...
GeneDavis Posted September 12, 2024 Share Posted September 12, 2024 Every deck is a "deck room" and in its spec dialog you can set its height. The outside staircase I show in this pic has two decks, and the bottom step is a slab that acts as the first step up off grade and the bearing for the stair stringer set. You need to learn to control stairs, their elevation locks, etc. You may need to do some 2D CAD workout to determine elevations. Link to comment Share on other sites More sharing options...
jjifmeyer Posted September 12, 2024 Author Share Posted September 12, 2024 Yes, I understand that they are rooms labeled as Deck, I just don't no where to set the elevation? Could you send a pict where that is? I imagine it is somewhere here but not sure? Thanks Link to comment Share on other sites More sharing options...
GeneDavis Posted September 12, 2024 Share Posted September 12, 2024 Type in a new number for "floor." May something like -30 inches, which equates to four steps down each 7.5". Link to comment Share on other sites More sharing options...
jjifmeyer Posted September 12, 2024 Author Share Posted September 12, 2024 Thank you so much, it was driving me crazy. Link to comment Share on other sites More sharing options...
ValleyGuy Posted September 12, 2024 Share Posted September 12, 2024 @jjifmeyer you could also just use a landing. They work well every time I need outside stairs and seem to be easier to manipulate / move than rooms. Link to comment Share on other sites More sharing options...
