JenniferK Posted September 7, 2024 Share Posted September 7, 2024 Does anyone have any suggestions for adding the deck louver detail below the header in the attached pictures? We are adding 2 more covered decks on a different side of this house and they would like to match this detail. I am using CA 16 Link to comment Share on other sites More sharing options...
Solution VHampton Posted September 7, 2024 Solution Share Posted September 7, 2024 3D solids would be the best pathway. Once the frame and louvers are made, the various solids can be made into a symbol. (click on each solid, and once all are selected)----> Make symbol. The new symbol can then be made longer or taller as necessary. The attached plan shows how the progression went from solids to a symbol. good luck! ...it's not as complicated as it seems. Untitled 1.planFetching info... 2 Link to comment Share on other sites More sharing options...
GeneDavis Posted September 7, 2024 Share Posted September 7, 2024 You can learn about multiple stretch planes when doing this. It'll be fun and instructive. 1 Link to comment Share on other sites More sharing options...
JenniferK Posted September 7, 2024 Author Share Posted September 7, 2024 Thanks so much for your help. Link to comment Share on other sites More sharing options...
VHampton Posted September 8, 2024 Share Posted September 8, 2024 You're quite welcome. 3D solids are an invaluable tool. There's no limits to house design because of what they can do. Link to comment Share on other sites More sharing options...
