Is it possible to reduce the 'Tri-count' of models exported from Chief architect?
VHI_WMA
When I export my chief models into lets say unity, the tri count is very high and can cause lagging or resolution issues, I think the cabinets alone add a lot to this. Is there a way to break down or explode these objects to simplify them without having to model things like cabinets from scratch?
The main way to reduce the surface count is to turn off the layers for things you don't need.
This tech article talks about optimizing a model for exporting to the 3D viewer which might help:
https://www.chiefarchitect.com/support/article/KB-03044/optimizing-a-chief-architect-plan-for-export-to-the-3d-viewer.html
On top of what DB said you would need a third party software like blender to decimate. Honestly you wouldn't be able to reduce it all that much, most of the tris in cabinets are appropriate for the level of modeling and is a pretty low poly modeler
