Robert_Designer Posted August 30, 2024 Share Posted August 30, 2024 When I attempt to print a layout to my HP DesignJet T640 D-sized printer, the Chief Architect File > Print > Print dialogue box does not list any architectural paper sizes such as ARCH D. It did in the past, but suddenly it has stopped displaying the usual sizes. Instead, it shows a short list of what looks like only small paper sizes: 8.5 x 13 184x260mm 195x270mm A4 A5 etc. I've been using and printing to the D-sized printer from Chief Architect successfully for over a year. This suddenly started happening and I can't figure out why. I am using X16 and I have confirmed the software is up to date. I am using a Mac Studio with Sonoma (14.6.1) It happens across ALL layouts. I have rebooted multiple times and it still happens. I have removed the HP printer from the Mac's printer list and re-installed it. When I go to File > Print > Customize Sheet Sizes the full list of sheet sizes are there, including ARCH D. When I create a NEW sheet size using that dialog box, the new sheet size does not appear in the printer's list of available sizes. I get the full list of paper sizes only if I select "Chief Architect Save as PDF". If I then output to a PDF, I am able to print successfully to the HP Printer in D-sized by using the PDF file with the Preview application instead of Chief Architect. But of course that's a wasteful work-around. I would like to print directly from Chief Architect like I was previously. What am I missing? Link to comment Share on other sites More sharing options...
joey_martin Posted August 30, 2024 Share Posted August 30, 2024 Sounds like a print driver issue not a Chief issue. My Epson Sc-2100 had that happen after a Microsoft update. 1 Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 30, 2024 Share Posted August 30, 2024 You can uninstall - reinstall your print drivers making sure you have the latest ones and see if that helps. Your driver should offer the various print sizes via a dropdown menu in its dialog. DJP Link to comment Share on other sites More sharing options...
