Cadwork22 Posted August 25, 2024 Share Posted August 25, 2024 Another question sorry, the upstairs window isn't penetrating the wall, see attached photo. Thank you. Link to comment Share on other sites More sharing options...
Cadwork22 Posted August 25, 2024 Author Share Posted August 25, 2024 Devin (4).zip Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 25, 2024 Share Posted August 25, 2024 Unless you have set up "Auto Rebuild Framing" you thereafter must manually reorder framing to be rebuilt after making 3D changes like adding wall penetrations like windows and doors. DJP Link to comment Share on other sites More sharing options...
Cadwork22 Posted August 25, 2024 Author Share Posted August 25, 2024 What do you mean reorder, is there a quick way to delete all framing, made changes, and then frame everything again. Link to comment Share on other sites More sharing options...
Solution rlackore Posted August 26, 2024 Solution Share Posted August 26, 2024 Actually, the window IS cutting the upper wall, but the lower wall has been "dragged" up to overlap the upper wall; so, what you're seeing is the lower wall occluding the window and the tall garage door. Select the lower wall and tick the checkbox Wall Specification>Structure>Default wall Heights>Default Wall Top Height. 1 1 Link to comment Share on other sites More sharing options...
