Cadwork22 Posted August 25, 2024 Share Posted August 25, 2024 I have 8 stud/1joists that I need to span across a 50 ft wall. Then I can use fixed glass windows between the columns. See attached, I've tried making elevations, and there is no centering tool which is what I really need. Two of the columns are above the sliding door section. The space between the columns need to be equal length. Thanks in advance. 1 Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 25, 2024 Share Posted August 25, 2024 In an elevation camera you can draw temporary CAD lines that you can precisely dimension and use to locate the column's centers as you wish. DJP Link to comment Share on other sites More sharing options...
Solution Cadwork22 Posted August 25, 2024 Author Solution Share Posted August 25, 2024 Nice, that should work, the image above is a camera image, how can you do an elevation from inside a structure. Link to comment Share on other sites More sharing options...
Rich_Winsor Posted August 26, 2024 Share Posted August 26, 2024 11 hours ago, Cadwork22 said: how can you do an elevation from inside a structure 1 Link to comment Share on other sites More sharing options...
clearvuedesign Posted August 31, 2024 Share Posted August 31, 2024 Link to comment Share on other sites More sharing options...
