RachelbyDesign Posted August 21, 2024 Share Posted August 21, 2024 I need to create a fixed door in a house that looks like they were going to put a slider in there and changed their mind. I would like the plans to reflect how the house currently looks but when I create the fixed door, it puts the "door" towards the inside. I thought "that's okay, I'll just reverse the door symbol" but for some reason, it is greyed out and I can't figure out why. I'm sure this has a really stupid simple answer but I just can't find it. Any help is much appreciated. I'm currently using X15 but would be willing to go up to X16 if that would fix my issue. Link to comment Share on other sites More sharing options...
Solution ericepv Posted August 21, 2024 Solution Share Posted August 21, 2024 Have you tried using the 'Change Swing Side' button? It's on the lower toolbar. Link to comment Share on other sites More sharing options...
RachelbyDesign Posted August 22, 2024 Author Share Posted August 22, 2024 Thank you! That worked perfectly. I knew it had to be something simple haha. Link to comment Share on other sites More sharing options...
DBCooper Posted August 22, 2024 Share Posted August 22, 2024 FYI, the "reverse int/ext" option is only available if your door style is using a library symbol. If you are using one of the built in door styles (such as slab, panel, or glass panel) you can't reverse it. Reversing it doesn't change the position though so it probably wouldn't help in this case. I think Eric is right and the "change swing side" will do what you want. In X16, you can also move the door in/out by any amount you want for cases where you don't want it aligned with either the outside or inside of the wall. Link to comment Share on other sites More sharing options...
