broken in the 3D model
RangerKatana
You'll find that this is a bit weird, but here's a solution:
  1. on the foundation level, ensure that the exterior of the foundation wall is aligned with the exterior of the framed wall above...exactly. Use a cad line or point to help snap into place.
  2. select the foundation wall and set it to be a Pony Wall; the upper wall should be Brick-4 ...see image below for settings.
