RangerKatana Posted August 8, 2024 Share Posted August 8, 2024 I installed a bay window in the wall and I raised height 38"from floor, but the wall appears broken in the 3D model. Can you tell me what might be wrong? Link to comment Share on other sites More sharing options...
SNestor Posted August 8, 2024 Share Posted August 8, 2024 If you would post your plan file...that will help you get a good answer. Thanks. Link to comment Share on other sites More sharing options...
RangerKatana Posted August 8, 2024 Author Share Posted August 8, 2024 5 hours ago, SNestor said: If you would post your plan file...that will help you get a good answer. Thanks. Thank you for your advice. I uploaded. Please see and guide me. Thanks grey stucco-slab.plan Link to comment Share on other sites More sharing options...
robdyck Posted August 8, 2024 Share Posted August 8, 2024 You'll find that this is a bit weird, but here's a solution: on the foundation level, ensure that the exterior of the foundation wall is aligned with the exterior of the framed wall above...exactly. Use a cad line or point to help snap into place. select the foundation wall and set it to be a Pony Wall; the upper wall should be Brick-4 ...see image below for settings. Link to comment Share on other sites More sharing options...
