WillBB Posted August 3, 2024 Share Posted August 3, 2024 Can any explain whey a sidelight will not mull to an entry door on the latch side only? Troubleshooting I've worked on - Tried both fixed doors for sidelights, and windows. - Tried deleting everything and starting fresh - Checked for matching heights at bottom / top - Tried mulling left side to door, then mulled object to right transom. Link to comment Share on other sites More sharing options...
scottharris Posted August 3, 2024 Share Posted August 3, 2024 Can you post the plan? 1 Link to comment Share on other sites More sharing options...
DBCooper Posted August 3, 2024 Share Posted August 3, 2024 Nope, not without the plan. You could try deleting the right side light and then using copy on the left one, and then reflect about the center of the door, and then see if it works. That would tell you that you had the exact same side light on both sides. Link to comment Share on other sites More sharing options...
