Follow up problem with furring in 4" walls
SkyTree-Greg
Go to solution Solved by DBCooper,
So KBird1 was nice enough to solve my original problem (see topic posted yesterday) of furring being in the wall layer instead of sheetrock. Unchecking the "framing" radio box associated with the drywall layer did that.
The problem that's now popped up is that furring is being generated inside the 3.5" framing layer. It shows up in both plan view and in framing overview perspectives. There's no rhyme or reason to its placement, as it displays inside of or through a normal framing member, or through a  shower niche. Turning off the framing radio box of materials property on the actual framing layer, gets rid of both general framing members, PLUS the furring pieces.
Thanks
Greg
SkyTreeAZ LLC
Running
Windows 10 Home
     Ver. 10.0.19045 Build 19045
GEOForce RTX 3080
11th Gen Intel(R) Core(TM) i7-11700K @ 3.60GHz   3.60 GHz
32.0 GB (31.8 GB usable)
64-bit operating system, x64-based processor
Phillips Remodel FURRING ISSUE.plan
FURRING ISSUE inside walls.pdf FURRING ISSUE perspective.pdf FURRING ISSUE perspective 2.pdf
1 hour ago, DBCooper said:
I think they are just left overs.  Fix the interior wall type and then rebuild the framing.
sounds like a good Start if Wall framing is not on Auto.
Previous post for others....
https://chieftalk.chiefarchitect.com/topic/42855-furring-applied-one-side-of-interior-4-walls-on-build-framing/?tab=comments#comment-315457
