Alchemyjim Posted July 21, 2024 Share Posted July 21, 2024 I like the ability to turn off the gutter of selected roof lines. But why is there no ability to do the same with fascia? In certain conditions the roof meets a wall above a living area. When the roof is flat the lower portion of the fascia will often appear below the ceiling line. What is the best way to handle this condition? Thanks Link to comment Share on other sites More sharing options...
MPDesign Posted July 23, 2024 Share Posted July 23, 2024 Hi Jim, I thought about this and tested my theory in X16, it should be the same in previous versions as well. I would suggest that you turn off the fascia and use the shadow board feature as a fascia. The shadow board has the ability to be turned off per roof edge. 2 Link to comment Share on other sites More sharing options...
tundra_dweller Posted July 23, 2024 Share Posted July 23, 2024 17 minutes ago, MPDesign said: I would suggest that you turn off the fascia and use the shadow board feature as a fascia. The shadow board has the ability to be turned off per roof edge. Nice workaround! Link to comment Share on other sites More sharing options...
MPDesign Posted July 23, 2024 Share Posted July 23, 2024 Thank you Brett! I try and keep the solutions within the tools at our disposal. The nice part about this method is you can add multiple trim boards as desired. Link to comment Share on other sites More sharing options...
Alchemyjim Posted July 29, 2024 Author Share Posted July 29, 2024 Thanks. Great solution! On 7/23/2024 at 8:00 AM, MPDesign said: Hi Jim, I thought about this and tested my theory in X16, it should be the same in previous versions as well. I would suggest that you turn off the fascia and use the shadow board feature as a fascia. The shadow board has the ability to be turned off per roof edge. Link to comment Share on other sites More sharing options...
jorgearaya Posted July 29, 2024 Share Posted July 29, 2024 Please go to this post and keep asking for this to be resolved! There's much more work to do to improve on roof planes. Thank you, Link to comment Share on other sites More sharing options...
