Joining Pline roads from terrain.
Cadwork22
Go to solution Solved by glennw,
  • Solution
You can draw one road section and then just drag a new road section off the end of that one.
The 2 road sections will join smoothly.
Only problem is this will result in a sharp junction between the 2 road sections.
1068121769_Screenshot2024-07-13at12_29_30pm.thumb.jpg.612d2dfdaa1e1cc2c9b00f5ba3c81766.jpg
I am guessing you want a curved join between the 2 road sections?
In that case, draw a straight road section.
Curve it using the Change Line/Arc tool on the Edit menu and then shape it as needed.
You can then add new straight road sections to each end of the curved section.
947487493_Screenshot2024-07-13at12_26_46pm.thumb.jpg.2347ee06b9ca62196c94306fedbc12cf.jpg
