Cadwork22 Posted Saturday at 06:30 PM Share Posted Saturday at 06:30 PM I found the Column I want to use in Millwork under the Library Browser. However, having difficulties placing inside wall. See attached. Thanks as always. Link to comment Share on other sites More sharing options...
Cadwork22 Posted Saturday at 06:49 PM Author Share Posted Saturday at 06:49 PM Also, I'm shading the rooms with Fill-Color, however it's shading the electrical, and mechanical, these need to be blank, is there a layer for this? Link to comment Share on other sites More sharing options...
Kbird1 Posted Saturday at 07:15 PM Share Posted Saturday at 07:15 PM 43 minutes ago, Cadwork22 said: I found the Column I want to use in Millwork under the Library Browser. However, having difficulties placing inside wall. See attached. Thanks as always. Check the Column's DBX Tabs it maybe set to stop at walls ? You should however be able to move it into the Wall with the Ctrl Key held down ( disables bumping ) M. 1 Link to comment Share on other sites More sharing options...
Cadwork22 Posted Saturday at 07:49 PM Author Share Posted Saturday at 07:49 PM Using the post option, which option in the drop down would be closest to a wall column? Link to comment Share on other sites More sharing options...
rlackore Posted 23 hours ago Share Posted 23 hours ago On 6/29/2024 at 1:30 PM, Cadwork22 said: I found the Column I want to use in Millwork under the Library Browser. However, having difficulties placing inside wall. Turn off Bumping/Pushing [Edit>Snap Settings>Bumping/Pushing], then try moving the column. Link to comment Share on other sites More sharing options...
rlackore Posted 23 hours ago Share Posted 23 hours ago On 6/29/2024 at 1:49 PM, Cadwork22 said: Also, I'm shading the rooms with Fill-Color, however it's shading the electrical, and mechanical, these need to be blank, is there a layer for this? You will have to modify the Symbol's 2D CAD Block using the Edit CAD Block tool to give the bounding geometry a solid Fill Style. Link to comment Share on other sites More sharing options...
