JamesG Posted March 8, 2015 Share Posted March 8, 2015 I want to copy my house so that I can remodel on the computer first. I have a by-level home. the help says that is a daylight basement. I cant seem to understand the steps for creating a daylight basement. Can anyone help me Link to comment Share on other sites More sharing options...
joey_martin Posted March 8, 2015 Share Posted March 8, 2015 You need to create pony walls for the daylight area and set the terrain to the proper level. If you are not going to worry about the terrain, then the pony walls will work just fine. Link to comment Share on other sites More sharing options...
Kbird1 Posted March 8, 2015 Share Posted March 8, 2015 James , by chance are you using a Home Designer Title by Chief Architect rather than CA Premier ? Home Designer has it's own Help Forum where you will get better answers related to whatever title you are using. You should add your Title and Version to your Forum signature as different versions have different Tools and thus answers to your question . there is also a Knowledgebase (KB) Area with tutorials , and I believe there is one for this question ,however it is down this weekend for maintenance it appears. https://hometalk.chiefarchitect.com/ Link to comment Share on other sites More sharing options...
Kbird1 Posted March 9, 2015 Share Posted March 9, 2015 KB is up again , here is the links to a split level and daylight tutorials http://www.chiefarchitect.com/support/article/KB-00932/ http://www.chiefarchitect.com/support/article/KB-00376/ http://www.homedesignersoftware.com/support/article/KB-00868/ http://www.homedesignersoftware.com/support/article/KB-00718/ Link to comment Share on other sites More sharing options...
