wkshank Posted June 13, 2024 Share Posted June 13, 2024 Setting the bottom of course just moves where the quoins begin, but the "outie" sections stay where they are. I need the bit at the frieze NOT to have a quoin sticking out, and the way it's generating is exactly opposite of what I need (need 3 bricks out, then 3 bricks in, but it's doing the reverse order vertically). Workaround? A setting I can't find? Link to comment Share on other sites More sharing options...
DBCooper Posted June 13, 2024 Share Posted June 13, 2024 Did you try setting "swap start block"? Link to comment Share on other sites More sharing options...
wkshank Posted June 13, 2024 Author Share Posted June 13, 2024 Swap only works if you're alternating large and small blocks... maybe I'll try doing that, and set the small one at zero thickness with zero space between ?? Link to comment Share on other sites More sharing options...
wkshank Posted June 13, 2024 Author Share Posted June 13, 2024 oops nope, can't set more than one thickness. : ( Link to comment Share on other sites More sharing options...
glennw Posted June 14, 2024 Share Posted June 14, 2024 I am not sure if this helps or not. I used a Corner Board with a Quoin on top. Link to comment Share on other sites More sharing options...
DBCooper Posted June 16, 2024 Share Posted June 16, 2024 If Glenn's solution doesn't work for you, you should post a picture of what you are trying to do. Link to comment Share on other sites More sharing options...
